Time Before: 0.02468 seconds
Time After: 0.02983 seconds
Time Taken: 0.00515 seconds
Time Before: 0.02994 seconds
Time After: 0.03043 seconds
Time Before: 0.03068 seconds
Time After: 0.03081 seconds
Time Before: 0.03148 seconds
Time After: 0.03409 seconds
Time Taken: 0.00261 seconds
Time Before: 0.03087 seconds
Time After: 0.03819 seconds
Time Taken: 0.00731 seconds
Time Before: 0.04640 seconds
Time After: 0.04664 seconds
Time Before: 0.04851 seconds
Time After: 0.04973 seconds
Time Before: 0.04567 seconds
Time After: 0.04994 seconds
Time Taken: 0.00427 seconds
Time Before: 0.08887 seconds
Time After: 0.08900 seconds
Time Before: 0.41329 seconds
Time After: 0.41468 seconds
Time Taken: 0.00139 seconds
Time Before: 0.43005 seconds
Time After: 0.43025 seconds
Time Before: 0.43291 seconds
Time After: 0.43438 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=144581' WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.45310 seconds
Time After: 0.45341 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
