Time Before: 0.00222 seconds
Time After: 0.00281 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00293 seconds
Time After: 0.00331 seconds
Time Before: 0.00354 seconds
Time After: 0.00364 seconds
Time Before: 0.00438 seconds
Time After: 0.00692 seconds
Time Taken: 0.00254 seconds
Time Before: 0.00369 seconds
Time After: 0.01092 seconds
Time Taken: 0.00723 seconds
Time Before: 0.01277 seconds
Time After: 0.01322 seconds
Time Before: 0.01580 seconds
Time After: 0.01715 seconds
Time Taken: 0.00135 seconds
Time Before: 0.01214 seconds
Time After: 0.01732 seconds
Time Taken: 0.00518 seconds
Time Before: 0.02470 seconds
Time After: 0.02482 seconds
Time Before: 0.02664 seconds
Time After: 0.02800 seconds
Time Taken: 0.00136 seconds
End call of global.php: 0.030169010162354
Time Before: 0.03141 seconds
Time After: 0.03158 seconds
Time Before: 0.03384 seconds
Time After: 0.03557 seconds
Time Taken: 0.00174 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=144594', badlocation = 1
Time Before: 0.05050 seconds
Time After: 0.05089 seconds
Page generated in 0.049489974975586 seconds with 9 queries, spending 0.0086009502410889 doing MySQL queries and 0.040889024734497 doing PHP things.
