Time Before: 0.00187 seconds
Time After: 0.00248 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00259 seconds
Time After: 0.00316 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00345 seconds
Time After: 0.00357 seconds
Time Before: 0.00437 seconds
Time After: 0.00734 seconds
Time Taken: 0.00297 seconds
Time Before: 0.00362 seconds
Time After: 0.01073 seconds
Time Taken: 0.00711 seconds
Time Before: 0.01257 seconds
Time After: 0.01296 seconds
Time Before: 0.01604 seconds
Time After: 0.01738 seconds
Time Taken: 0.00135 seconds
Time Before: 0.01196 seconds
Time After: 0.01756 seconds
Time Taken: 0.00561 seconds
Time Before: 0.02239 seconds
Time After: 0.02252 seconds
Time Before: 0.02449 seconds
Time After: 0.02570 seconds
End call of global.php: 0.027369022369385
Time Before: 0.02871 seconds
Time After: 0.02885 seconds
Time Before: 0.03088 seconds
Time After: 0.03235 seconds
SET lastactivity = 1785299258, location = '/forums/private.php?do=newpm&explain=1&u=144603'
Time Before: 0.04471 seconds
Time After: 0.04511 seconds
Page generated in 0.04381799697876 seconds with 9 queries, spending 0.0087349414825439 doing MySQL queries and 0.035083055496216 doing PHP things.
