Time Before: 0.00139 seconds
Time After: 0.00188 seconds
Time Before: 0.00195 seconds
Time After: 0.00243 seconds
Time Before: 0.00280 seconds
Time After: 0.00294 seconds
Time Before: 0.00365 seconds
Time After: 0.00580 seconds
Time Taken: 0.00215 seconds
Time Before: 0.00298 seconds
Time After: 0.00930 seconds
Time Taken: 0.00631 seconds
Time Before: 0.01107 seconds
Time After: 0.01148 seconds
Time Before: 0.01412 seconds
Time After: 0.01528 seconds
Time Taken: 0.00116 seconds
Time Before: 0.01050 seconds
Time After: 0.01549 seconds
Time Taken: 0.00498 seconds
Time Before: 0.02142 seconds
Time After: 0.02156 seconds
Time Before: 0.02409 seconds
Time After: 0.02534 seconds
Time Before: 0.02943 seconds
Time After: 0.02963 seconds
Time Before: 0.03186 seconds
Time After: 0.03492 seconds
Time Taken: 0.00306 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=144612' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04902 seconds
Time After: 0.04942 seconds
