Time Before: 0.01284 seconds
Time After: 0.01781 seconds
Time Taken: 0.00497 seconds
Time Before: 0.01790 seconds
Time After: 0.01836 seconds
Time Before: 0.01856 seconds
Time After: 0.01868 seconds
Time Before: 0.01954 seconds
Time After: 0.02208 seconds
Time Taken: 0.00254 seconds
Time Before: 0.01875 seconds
Time After: 0.02608 seconds
Time Taken: 0.00734 seconds
Time Before: 0.03201 seconds
Time After: 0.03250 seconds
Time Before: 0.03415 seconds
Time After: 0.03538 seconds
Time Before: 0.03130 seconds
Time After: 0.03557 seconds
Time Taken: 0.00427 seconds
Time Before: 0.05353 seconds
Time After: 0.05366 seconds
Time Before: 0.06435 seconds
Time After: 0.06558 seconds
Time Before: 0.07342 seconds
Time After: 0.07372 seconds
Time Before: 0.07606 seconds
Time After: 0.07913 seconds
Time Taken: 0.00307 seconds
UPDATE session SET lastactivity = 1776891544, location = '/forums/private.php?do=newpm&explain=1&u=144625' WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.09670 seconds
Time After: 0.09704 seconds
