Time Before: 0.00145 seconds
Time After: 0.00190 seconds
Time Before: 0.00197 seconds
Time After: 0.00242 seconds
Time Before: 0.00274 seconds
Time After: 0.00288 seconds
Time Before: 0.00373 seconds
Time After: 0.00713 seconds
Time Taken: 0.00340 seconds
Time Before: 0.00294 seconds
Time After: 0.01216 seconds
Time Taken: 0.00922 seconds
Time Before: 0.01423 seconds
Time After: 0.01465 seconds
Time Before: 0.01713 seconds
Time After: 0.01837 seconds
Time Before: 0.01351 seconds
Time After: 0.01860 seconds
Time Taken: 0.00509 seconds
Time Before: 0.02541 seconds
Time After: 0.02559 seconds
Time Before: 0.02758 seconds
Time After: 0.02883 seconds
End call of global.php: 0.031344890594482
Time Before: 0.03267 seconds
Time After: 0.03281 seconds
Time Before: 0.03559 seconds
Time After: 0.03702 seconds
SET lastactivity = 1772651507, location = '/forums/private.php?do=newpm&explain=1&u=144704'
WHERE sessionhash = '600503b925d08d481e162d46884ab830'
Time Before: 0.05067 seconds
Time After: 0.05098 seconds
Page generated in 0.049726009368896 seconds with 9 queries, spending 0.0089750289916992 doing MySQL queries and 0.040750980377197 doing PHP things.
