Time Before: 0.03188 seconds
Time After: 0.03937 seconds
Time Taken: 0.00749 seconds
Time Before: 0.03948 seconds
Time After: 0.03993 seconds
Time Before: 0.04018 seconds
Time After: 0.04035 seconds
Time Before: 0.04107 seconds
Time After: 0.04388 seconds
Time Taken: 0.00281 seconds
Time Before: 0.04044 seconds
Time After: 0.04798 seconds
Time Taken: 0.00754 seconds
Time Before: 0.05845 seconds
Time After: 0.05891 seconds
Time Before: 0.06134 seconds
Time After: 0.06258 seconds
Time Before: 0.05767 seconds
Time After: 0.06282 seconds
Time Taken: 0.00515 seconds
Time Before: 0.10452 seconds
Time After: 0.10467 seconds
Time Before: 0.11593 seconds
Time After: 0.11723 seconds
End call of global.php: 0.11901307106018
Time Before: 0.13158 seconds
Time After: 0.13177 seconds
Time Before: 0.13404 seconds
Time After: 0.13552 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=144766'
Time Before: 0.15707 seconds
Time After: 0.15735 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.15589308738708 seconds with 9 queries, spending 0.0085194110870361 doing MySQL queries and 0.14737367630005 doing PHP things.
