Time Before: 0.00882 seconds
Time After: 0.01077 seconds
Time Taken: 0.00195 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.01087 seconds
Time After: 0.01132 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.01160 seconds
Time After: 0.01178 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.01262 seconds
Time After: 0.01493 seconds
Time Taken: 0.00231 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.01185 seconds
Time After: 0.01984 seconds
Time Taken: 0.00799 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.02318 seconds
Time After: 0.02390 seconds
Time Taken: 0.00071 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.02556 seconds
Time After: 0.02676 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.02246 seconds
Time After: 0.02701 seconds
Time Taken: 0.00455 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.04043 seconds
Time After: 0.04059 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.06011 seconds
Time After: 0.06143 seconds
Time Taken: 0.00133 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.07490 seconds
Time After: 0.07509 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.07826 seconds
Time After: 0.07982 seconds
Time Taken: 0.00157 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=144800' WHERE sessionhash = '4737b6efab9faed20c53299b3b330814'
Time Before: 0.10301 seconds
Time After: 0.10328 seconds
Memory Before: 5,997.547 KB
Memory After: 5,997.789 KB
