Time Before: 0.00253 seconds
Time After: 0.00303 seconds
Time Before: 0.00310 seconds
Time After: 0.00349 seconds
Time Before: 0.00367 seconds
Time After: 0.00379 seconds
Time Before: 0.00441 seconds
Time After: 0.00764 seconds
Time Taken: 0.00324 seconds
Time Before: 0.00384 seconds
Time After: 0.01305 seconds
Time Taken: 0.00921 seconds
Time Before: 0.01629 seconds
Time After: 0.01668 seconds
Time Before: 0.01928 seconds
Time After: 0.02056 seconds
Time Before: 0.01553 seconds
Time After: 0.02081 seconds
Time Taken: 0.00528 seconds
Time Before: 0.02697 seconds
Time After: 0.02709 seconds
Time Before: 0.03036 seconds
Time After: 0.03161 seconds
End call of global.php: 0.033540964126587
Time Before: 0.03502 seconds
Time After: 0.03515 seconds
Time Before: 0.03708 seconds
Time After: 0.03850 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=144835'
Time Before: 0.05176 seconds
Time After: 0.05231 seconds
Time Taken: 0.00054 seconds
Page generated in 0.050796985626221 seconds with 9 queries, spending 0.0088722705841064 doing MySQL queries and 0.041924715042114 doing PHP things.
