Time Before: 0.00139 seconds
Time After: 0.00192 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00201 seconds
Time After: 0.00259 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00281 seconds
Time After: 0.00298 seconds
Time Before: 0.00363 seconds
Time After: 0.00630 seconds
Time Taken: 0.00267 seconds
Time Before: 0.00303 seconds
Time After: 0.00973 seconds
Time Taken: 0.00670 seconds
Time Before: 0.01167 seconds
Time After: 0.01206 seconds
Time Before: 0.01454 seconds
Time After: 0.01589 seconds
Time Taken: 0.00135 seconds
Time Before: 0.01094 seconds
Time After: 0.01613 seconds
Time Taken: 0.00519 seconds
Time Before: 0.02154 seconds
Time After: 0.02174 seconds
Time Before: 0.02420 seconds
Time After: 0.02549 seconds
End call of global.php: 0.028187990188599
Time Before: 0.02956 seconds
Time After: 0.02979 seconds
Time Before: 0.03228 seconds
Time After: 0.03490 seconds
Time Taken: 0.00262 seconds
SET lastactivity = 1777016916, location = '/forums/private.php?do=newpm&explain=1&u=144872'
WHERE sessionhash = '87651ca345a619a09949038b7f47c9ec'
Time Before: 0.04894 seconds
Time After: 0.05176 seconds
Time Taken: 0.00282 seconds
Page generated in 0.048015117645264 seconds with 9 queries, spending 0.012327671051025 doing MySQL queries and 0.035687446594238 doing PHP things.
