Time Before: 0.01502 seconds
Time After: 0.01926 seconds
Time Taken: 0.00423 seconds
Time Before: 0.01933 seconds
Time After: 0.01974 seconds
Time Before: 0.01997 seconds
Time After: 0.02010 seconds
Time Before: 0.02087 seconds
Time After: 0.02365 seconds
Time Taken: 0.00277 seconds
Time Before: 0.02015 seconds
Time After: 0.02758 seconds
Time Taken: 0.00743 seconds
Time Before: 0.03405 seconds
Time After: 0.03446 seconds
Time Before: 0.03577 seconds
Time After: 0.03700 seconds
Time Before: 0.03334 seconds
Time After: 0.03725 seconds
Time Taken: 0.00391 seconds
Time Before: 0.05988 seconds
Time After: 0.06006 seconds
Time Before: 0.07067 seconds
Time After: 0.07197 seconds
End call of global.php: 0.073660135269165
Time Before: 0.07999 seconds
Time After: 0.08016 seconds
Time Before: 0.08256 seconds
Time After: 0.08405 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=144958'
Time Before: 0.10336 seconds
Time After: 0.10363 seconds
Page generated in 0.10242199897766 seconds with 9 queries, spending 0.0083744525909424 doing MySQL queries and 0.094047546386719 doing PHP things.
