Time Before: 0.02844 seconds
Time After: 0.03600 seconds
Time Taken: 0.00756 seconds
Time Before: 0.03612 seconds
Time After: 0.03713 seconds
Time Taken: 0.00101 seconds
Time Before: 0.03740 seconds
Time After: 0.03752 seconds
Time Before: 0.03830 seconds
Time After: 0.04042 seconds
Time Taken: 0.00212 seconds
Time Before: 0.03759 seconds
Time After: 0.04422 seconds
Time Taken: 0.00663 seconds
Time Before: 0.05418 seconds
Time After: 0.05475 seconds
Time Taken: 0.00057 seconds
Time Before: 0.05730 seconds
Time After: 0.05852 seconds
Time Before: 0.05247 seconds
Time After: 0.05881 seconds
Time Taken: 0.00634 seconds
Time Before: 0.08680 seconds
Time After: 0.08750 seconds
Time Taken: 0.00070 seconds
Time Before: 2.14177 seconds
Time After: 2.14337 seconds
Time Taken: 0.00159 seconds
Time Before: 2.15686 seconds
Time After: 2.15708 seconds
Time Before: 2.15970 seconds
Time After: 2.16113 seconds
UPDATE session SET lastactivity = 1777068796, location = '/forums/private.php?do=newpm&explain=1&u=144967' WHERE sessionhash = '87651ca345a619a09949038b7f47c9ec'
Time Before: 2.17995 seconds
Time After: 2.18028 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
