Time Before: 0.00272 seconds
Time After: 0.00395 seconds
Time Before: 0.00406 seconds
Time After: 0.00447 seconds
Time Before: 0.00471 seconds
Time After: 0.00484 seconds
Time Before: 0.00577 seconds
Time After: 0.00810 seconds
Time Taken: 0.00233 seconds
Time Before: 0.00491 seconds
Time After: 0.01386 seconds
Time Taken: 0.00895 seconds
Time Before: 0.01740 seconds
Time After: 0.01781 seconds
Time Before: 0.02100 seconds
Time After: 0.02220 seconds
Time Before: 0.01660 seconds
Time After: 0.02245 seconds
Time Taken: 0.00585 seconds
Time Before: 0.03106 seconds
Time After: 0.03120 seconds
Time Before: 0.03729 seconds
Time After: 0.03851 seconds
End call of global.php: 0.040431022644043
Time Before: 0.04369 seconds
Time After: 0.04404 seconds
Time Before: 0.04753 seconds
Time After: 0.05062 seconds
Time Taken: 0.00309 seconds
SET lastactivity = 1788992509, location = '/forums/private.php?do=newpm&explain=1&u=144986', badlocation = 1
Time Before: 0.06950 seconds
Time After: 0.06983 seconds
Page generated in 0.068371057510376 seconds with 9 queries, spending 0.0096008777618408 doing MySQL queries and 0.058770179748535 doing PHP things.
