Time Before: 0.00151 seconds
Time After: 0.00198 seconds
Time Before: 0.00205 seconds
Time After: 0.00397 seconds
Time Taken: 0.00193 seconds
Time Before: 0.00421 seconds
Time After: 0.00437 seconds
Time Before: 0.00512 seconds
Time After: 0.00777 seconds
Time Taken: 0.00264 seconds
Time Before: 0.00444 seconds
Time After: 0.01217 seconds
Time Taken: 0.00773 seconds
Time Before: 0.01498 seconds
Time After: 0.01535 seconds
Time Before: 0.01757 seconds
Time After: 0.01882 seconds
Time Before: 0.01398 seconds
Time After: 0.01900 seconds
Time Taken: 0.00502 seconds
Time Before: 0.02428 seconds
Time After: 0.02442 seconds
Time Before: 0.02643 seconds
Time After: 0.02768 seconds
End call of global.php: 0.030060768127441
Time Before: 0.03143 seconds
Time After: 0.03157 seconds
Time Before: 0.03374 seconds
Time After: 0.03525 seconds
Time Taken: 0.00151 seconds
SET lastactivity = 1789130078, location = '/forums/private.php?do=newpm&explain=1&u=145031', badlocation = 1
Time Before: 0.04853 seconds
Time After: 0.04904 seconds
Page generated in 0.047627925872803 seconds with 9 queries, spending 0.0098979473114014 doing MySQL queries and 0.037729978561401 doing PHP things.
