Time Before: 0.02039 seconds
Time After: 0.02872 seconds
Time Taken: 0.00833 seconds
Time Before: 0.02879 seconds
Time After: 0.02918 seconds
Time Before: 0.02942 seconds
Time After: 0.02955 seconds
Time Before: 0.03033 seconds
Time After: 0.03251 seconds
Time Taken: 0.00218 seconds
Time Before: 0.02961 seconds
Time After: 0.03660 seconds
Time Taken: 0.00699 seconds
Time Before: 0.04617 seconds
Time After: 0.04655 seconds
Time Before: 0.04894 seconds
Time After: 0.05015 seconds
Time Before: 0.04546 seconds
Time After: 0.05035 seconds
Time Taken: 0.00488 seconds
Time Before: 0.08610 seconds
Time After: 0.08640 seconds
Time Before: 0.11070 seconds
Time After: 0.11192 seconds
End call of global.php: 0.11428999900818
Time Before: 0.12628 seconds
Time After: 0.12642 seconds
Time Before: 0.12886 seconds
Time After: 0.13034 seconds
SET lastactivity = 1776668010, location = '/forums/private.php?do=newpm&explain=1&u=145090'
Time Before: 0.14804 seconds
Time After: 0.14834 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.14705395698547 seconds with 9 queries, spending 0.0077364444732666 doing MySQL queries and 0.13931751251221 doing PHP things.
