Time Before: 0.01768 seconds
Time After: 0.02197 seconds
Time Taken: 0.00429 seconds
Time Before: 0.02206 seconds
Time After: 0.02250 seconds
Time Before: 0.02272 seconds
Time After: 0.02288 seconds
Time Before: 0.02367 seconds
Time After: 0.02624 seconds
Time Taken: 0.00257 seconds
Time Before: 0.02293 seconds
Time After: 0.03033 seconds
Time Taken: 0.00740 seconds
Time Before: 0.03760 seconds
Time After: 0.03807 seconds
Time Before: 0.04101 seconds
Time After: 0.04222 seconds
Time Before: 0.03681 seconds
Time After: 0.04246 seconds
Time Taken: 0.00565 seconds
Time Before: 0.07237 seconds
Time After: 0.07251 seconds
Time Before: 0.09053 seconds
Time After: 0.09208 seconds
Time Taken: 0.00155 seconds
End call of global.php: 0.094559907913208
Time Before: 0.10206 seconds
Time After: 0.10225 seconds
Time Before: 0.10558 seconds
Time After: 0.10705 seconds
SET lastactivity = 1776793093, location = '/forums/private.php?do=newpm&explain=1&u=145111'
Time Before: 0.12441 seconds
Time After: 0.12476 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.12302088737488 seconds with 9 queries, spending 0.0085148811340332 doing MySQL queries and 0.11450600624084 doing PHP things.
