Time Before: 0.02801 seconds
Time After: 0.03572 seconds
Time Taken: 0.00771 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.03584 seconds
Time After: 0.03628 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.03651 seconds
Time After: 0.03663 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.03735 seconds
Time After: 0.03971 seconds
Time Taken: 0.00236 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.03670 seconds
Time After: 0.04336 seconds
Time Taken: 0.00666 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.04978 seconds
Time After: 0.05018 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.05284 seconds
Time After: 0.05404 seconds
Memory Before: 2,771.656 KB
Memory After: 2,771.516 KB
Time Before: 0.04912 seconds
Time After: 0.05429 seconds
Time Taken: 0.00517 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.547 KB
Time Before: 0.09502 seconds
Time After: 0.09522 seconds
Memory Before: 3,437.688 KB
Memory After: 3,438.203 KB
Time Before: 0.11606 seconds
Time After: 0.11731 seconds
Memory Before: 3,525.500 KB
Memory After: 3,526.094 KB
Time Before: 0.13196 seconds
Time After: 0.13215 seconds
Memory Before: 4,163.391 KB
Memory After: 4,163.820 KB
Time Before: 0.13491 seconds
Time After: 0.13637 seconds
Memory Before: 4,444.953 KB
Memory After: 4,446.641 KB
UPDATE session SET lastactivity = 1776612606, location = '/forums/private.php?do=newpm&explain=1&u=145164' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.15626 seconds
Time After: 0.15666 seconds
Memory Before: 4,919.563 KB
Memory After: 4,919.789 KB
