Time Before: 0.00357 seconds
Time After: 0.00464 seconds
Time Taken: 0.00108 seconds
Time Before: 0.00476 seconds
Time After: 0.00523 seconds
Time Before: 0.00554 seconds
Time After: 0.00568 seconds
Time Before: 0.00664 seconds
Time After: 0.00891 seconds
Time Taken: 0.00227 seconds
Time Before: 0.00576 seconds
Time After: 0.01429 seconds
Time Taken: 0.00853 seconds
Time Before: 0.01690 seconds
Time After: 0.01738 seconds
Time Before: 0.01927 seconds
Time After: 0.02046 seconds
Time Before: 0.01608 seconds
Time After: 0.02073 seconds
Time Taken: 0.00465 seconds
Time Before: 0.02745 seconds
Time After: 0.02759 seconds
Time Before: 0.02971 seconds
Time After: 0.03095 seconds
Time Before: 0.03382 seconds
Time After: 0.03397 seconds
Time Before: 0.03604 seconds
Time After: 0.03781 seconds
Time Taken: 0.00176 seconds
UPDATE session SET lastactivity = 1789016373, location = '/forums/private.php?do=newpm&explain=1&u=145173', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05137 seconds
Time After: 0.05172 seconds
