Time Before: 0.00130 seconds
Time After: 0.00171 seconds
Time Before: 0.00178 seconds
Time After: 0.00213 seconds
Time Before: 0.00230 seconds
Time After: 0.00245 seconds
Time Before: 0.00312 seconds
Time After: 0.00560 seconds
Time Taken: 0.00248 seconds
Time Before: 0.00249 seconds
Time After: 0.00916 seconds
Time Taken: 0.00667 seconds
Time Before: 0.01100 seconds
Time After: 0.01137 seconds
Time Before: 0.01285 seconds
Time After: 0.01405 seconds
Time Before: 0.01037 seconds
Time After: 0.01430 seconds
Time Taken: 0.00392 seconds
Time Before: 0.02037 seconds
Time After: 0.02049 seconds
Time Before: 0.02242 seconds
Time After: 0.02389 seconds
End call of global.php: 0.025542974472046
Time Before: 0.02701 seconds
Time After: 0.02792 seconds
Time Taken: 0.00091 seconds
Time Before: 0.02998 seconds
Time After: 0.03139 seconds
SET lastactivity = 1785301738, location = '/forums/private.php?do=newpm&explain=1&u=145185'
Time Before: 0.04387 seconds
Time After: 0.04423 seconds
Page generated in 0.042980909347534 seconds with 9 queries, spending 0.0087840557098389 doing MySQL queries and 0.034196853637695 doing PHP things.
