Time Before: 0.02832 seconds
Time After: 0.03658 seconds
Time Taken: 0.00826 seconds
Time Before: 0.03671 seconds
Time After: 0.03714 seconds
Time Before: 0.03740 seconds
Time After: 0.03755 seconds
Time Before: 0.03856 seconds
Time After: 0.04091 seconds
Time Taken: 0.00235 seconds
Time Before: 0.03765 seconds
Time After: 0.04561 seconds
Time Taken: 0.00796 seconds
Time Before: 0.05428 seconds
Time After: 0.05476 seconds
Time Before: 0.05779 seconds
Time After: 0.05902 seconds
Time Before: 0.05362 seconds
Time After: 0.05923 seconds
Time Taken: 0.00561 seconds
Time Before: 0.10514 seconds
Time After: 0.10527 seconds
Time Before: 0.13648 seconds
Time After: 0.13775 seconds
Time Before: 0.14633 seconds
Time After: 0.14657 seconds
Time Before: 0.14954 seconds
Time After: 0.15100 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=145191', badlocation = 1 WHERE sessionhash = 'e0f0ca8e3048a6e309b58c7aba652665'
Time Before: 0.17414 seconds
Time After: 0.17444 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
