Time Before: 0.00238 seconds
Time After: 0.00319 seconds
Time Taken: 0.00080 seconds
Time Before: 0.00330 seconds
Time After: 0.00380 seconds
Time Before: 0.00408 seconds
Time After: 0.00422 seconds
Time Before: 0.00510 seconds
Time After: 0.00876 seconds
Time Taken: 0.00366 seconds
Time Before: 0.00429 seconds
Time After: 0.01375 seconds
Time Taken: 0.00945 seconds
Time Before: 0.01558 seconds
Time After: 0.01596 seconds
Time Before: 0.01729 seconds
Time After: 0.01848 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01500 seconds
Time After: 0.01866 seconds
Memory After: 2,261.820 KB
Time Before: 0.02479 seconds
Time After: 0.02496 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02717 seconds
Time After: 0.02846 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.03332 seconds
Time After: 0.03349 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03638 seconds
Time After: 0.03782 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788910490, location = '/forums/private.php?do=newpm&explain=1&u=145203' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05316 seconds
Time After: 0.05341 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
