Time Before: 0.00226 seconds
Time After: 0.00296 seconds
Time Taken: 0.00070 seconds
Time Before: 0.00308 seconds
Time After: 0.00352 seconds
Time Before: 0.00372 seconds
Time After: 0.00381 seconds
Time Taken: 0.00009 seconds
Time Before: 0.00439 seconds
Time After: 0.00663 seconds
Time Taken: 0.00224 seconds
Time Before: 0.00386 seconds
Time After: 0.01004 seconds
Time Taken: 0.00618 seconds
Time Before: 0.01172 seconds
Time After: 0.01195 seconds
Time Before: 0.01403 seconds
Time After: 0.01520 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01119 seconds
Time After: 0.01541 seconds
Time Taken: 0.00423 seconds
Time Before: 0.02180 seconds
Time After: 0.02194 seconds
Time Before: 0.02423 seconds
Time After: 0.02549 seconds
Time Before: 0.02991 seconds
Time After: 0.03004 seconds
Time Before: 0.03297 seconds
Time After: 0.03441 seconds
UPDATE session SET lastactivity = 1782960382, location = '/forums/private.php?do=newpm&explain=1&u=145383', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.04858 seconds
Time After: 0.04881 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
