Time Before: 0.00224 seconds
Time After: 0.00276 seconds
Time Before: 0.00283 seconds
Time After: 0.00332 seconds
Time Before: 0.00358 seconds
Time After: 0.00372 seconds
Time Before: 0.00465 seconds
Time After: 0.00697 seconds
Time Taken: 0.00233 seconds
Time Before: 0.00380 seconds
Time After: 0.01035 seconds
Time Taken: 0.00656 seconds
Time Before: 0.01219 seconds
Time After: 0.01257 seconds
Time Before: 0.01564 seconds
Time After: 0.01685 seconds
Time Before: 0.01155 seconds
Time After: 0.01711 seconds
Time Taken: 0.00556 seconds
Time Before: 0.02361 seconds
Time After: 0.02377 seconds
Time Before: 0.02614 seconds
Time After: 0.02742 seconds
Time Before: 0.03097 seconds
Time After: 0.03114 seconds
Time Before: 0.03320 seconds
Time After: 0.03481 seconds
Time Taken: 0.00160 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=145399', badlocation = 1 WHERE sessionhash = 'f0a2de90bc45baf36aaf71071f1bfe42'
Time Before: 0.04924 seconds
Time After: 0.04963 seconds
