Time Before: 0.02477 seconds
Time After: 0.03106 seconds
Time Taken: 0.00629 seconds
Time Before: 0.03118 seconds
Time After: 0.03164 seconds
Time Before: 0.03195 seconds
Time After: 0.03211 seconds
Time Before: 0.03312 seconds
Time After: 0.03566 seconds
Time Taken: 0.00255 seconds
Time Before: 0.03220 seconds
Time After: 0.03979 seconds
Time Taken: 0.00760 seconds
Time Before: 0.04993 seconds
Time After: 0.05030 seconds
Time Before: 0.05182 seconds
Time After: 0.05300 seconds
Time Taken: 0.00117 seconds
Time Before: 0.04921 seconds
Time After: 0.05321 seconds
Time Taken: 0.00400 seconds
Time Before: 0.08179 seconds
Time After: 0.08193 seconds
Time Before: 0.09651 seconds
Time After: 0.09780 seconds
End call of global.php: 0.099725008010864
Time Before: 0.10693 seconds
Time After: 0.10713 seconds
Time Before: 0.10943 seconds
Time After: 0.11085 seconds
SET lastactivity = 1782992080, location = '/forums/private.php?do=newpm&explain=1&u=145405'
Time Before: 0.13530 seconds
Time After: 0.13567 seconds
Page generated in 0.13429808616638 seconds with 9 queries, spending 0.0081319808959961 doing MySQL queries and 0.12616610527039 doing PHP things.
