Time Before: 0.01351 seconds
Time After: 0.02159 seconds
Time Taken: 0.00808 seconds
Time Before: 0.02167 seconds
Time After: 0.02234 seconds
Time Taken: 0.00067 seconds
Time Before: 0.02273 seconds
Time After: 0.02298 seconds
Time Before: 0.02384 seconds
Time After: 0.02659 seconds
Time Taken: 0.00274 seconds
Time Before: 0.02305 seconds
Time After: 0.03066 seconds
Time Taken: 0.00761 seconds
Time Before: 0.03827 seconds
Time After: 0.03877 seconds
Time Before: 0.04069 seconds
Time After: 0.04188 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03736 seconds
Time After: 0.04204 seconds
Time Taken: 0.00468 seconds
Memory After: 2,261.820 KB
Time Before: 0.06208 seconds
Time After: 0.06274 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.08576 seconds
Time After: 0.08699 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.09683 seconds
Time After: 0.09699 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.09934 seconds
Time After: 0.10078 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789019132, location = '/forums/private.php?do=newpm&explain=1&u=145597' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.12560 seconds
Time After: 0.12585 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
