Time Before: 0.00136 seconds
Time After: 0.00186 seconds
Time Before: 0.00193 seconds
Time After: 0.00228 seconds
Time Before: 0.00248 seconds
Time After: 0.00259 seconds
Time Before: 0.00320 seconds
Time After: 0.00541 seconds
Time Taken: 0.00221 seconds
Time Before: 0.00264 seconds
Time After: 0.01008 seconds
Time Taken: 0.00744 seconds
Time Before: 0.01185 seconds
Time After: 0.01219 seconds
Time Before: 0.01454 seconds
Time After: 0.01577 seconds
Time Before: 0.01131 seconds
Time After: 0.01594 seconds
Time Taken: 0.00462 seconds
Time Before: 0.02250 seconds
Time After: 0.02262 seconds
Time Before: 0.02529 seconds
Time After: 0.02670 seconds
End call of global.php: 0.02855110168457
Time Before: 0.02973 seconds
Time After: 0.02985 seconds
Time Before: 0.03182 seconds
Time After: 0.03449 seconds
Time Taken: 0.00268 seconds
SET lastactivity = 1789065522, location = '/forums/private.php?do=newpm&explain=1&u=145621', badlocation = 1
Time Before: 0.05273 seconds
Time After: 0.05297 seconds
Page generated in 0.051445960998535 seconds with 9 queries, spending 0.0088210105895996 doing MySQL queries and 0.042624950408936 doing PHP things.
