Time Before: 0.02524 seconds
Time After: 0.03156 seconds
Time Taken: 0.00632 seconds
Time Before: 0.03164 seconds
Time After: 0.03224 seconds
Time Taken: 0.00060 seconds
Time Before: 0.03256 seconds
Time After: 0.03271 seconds
Time Before: 0.03346 seconds
Time After: 0.03604 seconds
Time Taken: 0.00258 seconds
Time Before: 0.03277 seconds
Time After: 0.04175 seconds
Time Taken: 0.00898 seconds
Time Before: 0.04968 seconds
Time After: 0.05007 seconds
Time Before: 0.05151 seconds
Time After: 0.05279 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04869 seconds
Time After: 0.05303 seconds
Time Taken: 0.00434 seconds
Memory After: 2,261.836 KB
Memory Used: 132.898 KB
Time Before: 0.08715 seconds
Time After: 0.08735 seconds
Memory Before: 2,815.383 KB
Memory After: 2,815.898 KB
Time Before: 0.10564 seconds
Time After: 0.10693 seconds
Memory Before: 2,903.578 KB
Memory After: 2,904.172 KB
End call of global.php: 0.10892701148987
Time Before: 0.12541 seconds
Time After: 0.12558 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.12856 seconds
Time After: 0.12999 seconds
Memory Before: 3,821.875 KB
Memory After: 3,823.563 KB
SET lastactivity = 1789107723, location = '/forums/private.php?do=newpm&explain=1&u=145700', badlocation = 1
Time Before: 0.14720 seconds
Time After: 0.14744 seconds
Memory Before: 4,287.914 KB
Memory After: 4,288.125 KB
Page generated in 0.14606094360352 seconds with 9 queries, spending 0.0083174705505371 doing MySQL queries and 0.13774347305298 doing PHP things.
