Time Before: 0.00164 seconds
Time After: 0.00215 seconds
Time Before: 0.00221 seconds
Time After: 0.00291 seconds
Time Taken: 0.00069 seconds
Time Before: 0.00317 seconds
Time After: 0.00334 seconds
Time Before: 0.00402 seconds
Time After: 0.00672 seconds
Time Taken: 0.00269 seconds
Time Before: 0.00339 seconds
Time After: 0.01018 seconds
Time Taken: 0.00679 seconds
Time Before: 0.01232 seconds
Time After: 0.01289 seconds
Time Taken: 0.00056 seconds
Time Before: 0.01527 seconds
Time After: 0.01653 seconds
Time Before: 0.01168 seconds
Time After: 0.01672 seconds
Time Taken: 0.00504 seconds
Time Before: 0.02200 seconds
Time After: 0.02214 seconds
Time Before: 0.02434 seconds
Time After: 0.02558 seconds
Time Before: 0.02845 seconds
Time After: 0.02863 seconds
Time Before: 0.03065 seconds
Time After: 0.03207 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=145717', badlocation = 1 WHERE sessionhash = '7775e95b18bef93607bc556467059588'
Time Before: 0.04466 seconds
Time After: 0.04501 seconds
