Time Before: 0.00141 seconds
Time After: 0.00222 seconds
Time Taken: 0.00081 seconds
Time Before: 0.00229 seconds
Time After: 0.00270 seconds
Time Before: 0.00289 seconds
Time After: 0.00313 seconds
Time Before: 0.00388 seconds
Time After: 0.00774 seconds
Time Taken: 0.00386 seconds
Time Before: 0.00318 seconds
Time After: 0.01117 seconds
Time Taken: 0.00799 seconds
Time Before: 0.01315 seconds
Time After: 0.01364 seconds
Time Before: 0.01683 seconds
Time After: 0.01809 seconds
Time Before: 0.01244 seconds
Time After: 0.01833 seconds
Time Taken: 0.00589 seconds
Time Before: 0.02471 seconds
Time After: 0.02484 seconds
Time Before: 0.02688 seconds
Time After: 0.02812 seconds
Time Before: 0.03110 seconds
Time After: 0.03124 seconds
Time Before: 0.03331 seconds
Time After: 0.03476 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=145729', badlocation = 1 WHERE sessionhash = '785a5ccc852039ad054a2e3a39163c15'
Time Before: 0.04743 seconds
Time After: 0.04857 seconds
Time Taken: 0.00114 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
