Time Before: 0.00465 seconds
Time After: 0.00607 seconds
Time Before: 0.00617 seconds
Time After: 0.00661 seconds
Time Before: 0.00688 seconds
Time After: 0.00704 seconds
Time Before: 0.00812 seconds
Time After: 0.01098 seconds
Time Taken: 0.00286 seconds
Time Before: 0.00712 seconds
Time After: 0.01584 seconds
Time Taken: 0.00872 seconds
Time Before: 0.01871 seconds
Time After: 0.01909 seconds
Time Before: 0.02203 seconds
Time After: 0.02341 seconds
Time Taken: 0.00138 seconds
Time Before: 0.01798 seconds
Time After: 0.02361 seconds
Time Taken: 0.00563 seconds
Time Before: 0.03175 seconds
Time After: 0.03189 seconds
Time Before: 0.03616 seconds
Time After: 0.03751 seconds
Time Taken: 0.00135 seconds
End call of global.php: 0.040712833404541
Time Before: 0.04232 seconds
Time After: 0.04344 seconds
Time Taken: 0.00112 seconds
Time Before: 0.04562 seconds
Time After: 0.04709 seconds
SET lastactivity = 1785385248, location = '/forums/private.php?do=newpm&explain=1&u=145761', badlocation = 1
WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.06341 seconds
Time After: 0.06744 seconds
Time Taken: 0.00403 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.061921834945679 seconds with 9 queries, spending 0.013334035873413 doing MySQL queries and 0.048587799072266 doing PHP things.
