Time Before: 0.02239 seconds
Time After: 0.03074 seconds
Time Taken: 0.00835 seconds
Time Before: 0.03085 seconds
Time After: 0.03186 seconds
Time Taken: 0.00101 seconds
Time Before: 0.03242 seconds
Time After: 0.03256 seconds
Time Before: 0.03319 seconds
Time After: 0.03549 seconds
Time Taken: 0.00230 seconds
Time Before: 0.03261 seconds
Time After: 0.03974 seconds
Time Taken: 0.00712 seconds
Time Before: 0.04915 seconds
Time After: 0.04938 seconds
Time Before: 0.05137 seconds
Time After: 0.05257 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04855 seconds
Time After: 0.05281 seconds
Time Taken: 0.00426 seconds
Memory After: 2,261.836 KB
Time Before: 0.10085 seconds
Time After: 0.10099 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.79272 seconds
Time After: 0.79459 seconds
Time Taken: 0.00187 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.80618 seconds
Time After: 0.80639 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.80973 seconds
Time After: 0.81140 seconds
Time Taken: 0.00167 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789037549, location = '/forums/private.php?do=newpm&explain=1&u=14579', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.83447 seconds
Time After: 0.83470 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
