Time Before: 0.02447 seconds
Time After: 0.03454 seconds
Time Taken: 0.01007 seconds
Time Before: 0.03465 seconds
Time After: 0.03509 seconds
Time Before: 0.03536 seconds
Time After: 0.03548 seconds
Time Before: 0.03635 seconds
Time After: 0.03934 seconds
Time Taken: 0.00299 seconds
Time Before: 0.03555 seconds
Time After: 0.04356 seconds
Time Taken: 0.00802 seconds
Time Before: 0.05119 seconds
Time After: 0.05156 seconds
Time Before: 0.05296 seconds
Time After: 0.05490 seconds
Time Taken: 0.00195 seconds
Time Before: 0.05050 seconds
Time After: 0.05509 seconds
Time Taken: 0.00459 seconds
Time Before: 0.09327 seconds
Time After: 0.09343 seconds
Time Before: 0.11304 seconds
Time After: 0.11429 seconds
End call of global.php: 0.11631608009338
Time Before: 0.12689 seconds
Time After: 0.12719 seconds
Time Before: 0.12994 seconds
Time After: 0.13147 seconds
Time Taken: 0.00153 seconds
SET lastactivity = 1785420257, location = '/forums/private.php?do=newpm&explain=1&u=145792'
Time Before: 0.15012 seconds
Time After: 0.15048 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.14907693862915 seconds with 9 queries, spending 0.0094397068023682 doing MySQL queries and 0.13963723182678 doing PHP things.
