Time Before: 0.02492 seconds
Time After: 0.03245 seconds
Time Taken: 0.00754 seconds
Time Before: 0.03257 seconds
Time After: 0.03302 seconds
Time Before: 0.03322 seconds
Time After: 0.03336 seconds
Time Before: 0.03445 seconds
Time After: 0.03712 seconds
Time Taken: 0.00267 seconds
Time Before: 0.03341 seconds
Time After: 0.04166 seconds
Time Taken: 0.00825 seconds
Time Before: 0.05161 seconds
Time After: 0.05206 seconds
Time Before: 0.05524 seconds
Time After: 0.05716 seconds
Time Taken: 0.00192 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.05094 seconds
Time After: 0.05743 seconds
Time Taken: 0.00649 seconds
Memory After: 2,261.703 KB
Time Before: 0.09213 seconds
Time After: 0.09227 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.11440 seconds
Time After: 0.11565 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.12723 seconds
Time After: 0.12777 seconds
Time Taken: 0.00054 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.13092 seconds
Time After: 0.13238 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=145794' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.14924 seconds
Time After: 0.14950 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
