Time Before: 0.01940 seconds
Time After: 0.02897 seconds
Time Taken: 0.00957 seconds
Time Before: 0.02908 seconds
Time After: 0.02975 seconds
Time Taken: 0.00067 seconds
Time Before: 0.03001 seconds
Time After: 0.03012 seconds
Time Before: 0.03104 seconds
Time After: 0.03341 seconds
Time Taken: 0.00237 seconds
Time Before: 0.03020 seconds
Time After: 0.03744 seconds
Time Taken: 0.00724 seconds
Time Before: 0.04518 seconds
Time After: 0.04563 seconds
Time Before: 0.04831 seconds
Time After: 0.04973 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04441 seconds
Time After: 0.04996 seconds
Time Taken: 0.00556 seconds
Memory After: 2,261.820 KB
Time Before: 0.07471 seconds
Time After: 0.07494 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.10517 seconds
Time After: 0.10641 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.11830 seconds
Time After: 0.11847 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.12074 seconds
Time After: 0.12216 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789033521, location = '/forums/private.php?do=newpm&explain=1&u=145810' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.13977 seconds
Time After: 0.14004 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
