Time Before: 0.00882 seconds
Time After: 0.01230 seconds
Time Taken: 0.00347 seconds
Time Before: 0.01240 seconds
Time After: 0.01363 seconds
Time Before: 0.01413 seconds
Time After: 0.01472 seconds
Time Taken: 0.00059 seconds
Time Before: 0.01555 seconds
Time After: 0.01763 seconds
Time Taken: 0.00208 seconds
Time Before: 0.01480 seconds
Time After: 0.02239 seconds
Time Taken: 0.00758 seconds
Time Before: 0.02858 seconds
Time After: 0.02892 seconds
Time Before: 0.03134 seconds
Time After: 0.03259 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.02786 seconds
Time After: 0.03281 seconds
Time Taken: 0.00495 seconds
Memory After: 2,261.820 KB
Time Before: 0.04973 seconds
Time After: 0.05011 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.06123 seconds
Time After: 0.06257 seconds
Time Taken: 0.00133 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.064819097518921
Time Before: 0.06750 seconds
Time After: 0.06769 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.07023 seconds
Time After: 0.07169 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789065537, location = '/forums/private.php?do=newpm&explain=1&u=145816'
Time Before: 0.09041 seconds
Time After: 0.09070 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.089287996292114 seconds with 9 queries, spending 0.0091488361358643 doing MySQL queries and 0.08013916015625 doing PHP things.
