Time Before: 0.01518 seconds
Time After: 0.02309 seconds
Time Taken: 0.00791 seconds
Time Before: 0.02316 seconds
Time After: 0.02377 seconds
Time Taken: 0.00060 seconds
Time Before: 0.02405 seconds
Time After: 0.02423 seconds
Time Before: 0.02500 seconds
Time After: 0.02790 seconds
Time Taken: 0.00290 seconds
Time Before: 0.02430 seconds
Time After: 0.03221 seconds
Time Before: 0.04445 seconds
Time After: 0.04494 seconds
Time Before: 0.04663 seconds
Time After: 0.04781 seconds
Time Taken: 0.00118 seconds
Time Before: 0.04369 seconds
Time After: 0.04800 seconds
Time Taken: 0.00431 seconds
Time Before: 0.08080 seconds
Time After: 0.08097 seconds
Time Before: 0.09843 seconds
Time After: 0.09976 seconds
Time Taken: 0.00133 seconds
Time Before: 0.10617 seconds
Time After: 0.10639 seconds
Time Before: 0.10960 seconds
Time After: 0.11119 seconds
Time Taken: 0.00159 seconds
UPDATE session SET lastactivity = 1783054718, location = '/forums/private.php?do=newpm&explain=1&u=145902' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.13167 seconds
Time After: 0.13199 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
