Time Before: 0.02308 seconds
Time After: 0.02972 seconds
Time Taken: 0.00664 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02984 seconds
Time After: 0.03019 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.03043 seconds
Time After: 0.03056 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.03143 seconds
Time After: 0.03381 seconds
Time Taken: 0.00238 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.03066 seconds
Time After: 0.03833 seconds
Time Taken: 0.00767 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.04575 seconds
Time After: 0.04620 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.04753 seconds
Time After: 0.04876 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.04499 seconds
Time After: 0.04901 seconds
Time Taken: 0.00402 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.07959 seconds
Time After: 0.07971 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.12359 seconds
Time After: 0.12495 seconds
Time Taken: 0.00135 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
End call of global.php: 0.12689900398254
Time Before: 0.14829 seconds
Time After: 0.14848 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.15391 seconds
Time After: 0.15558 seconds
Time Taken: 0.00166 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
SET lastactivity = 1773095856, location = '/forums/private.php?do=newpm&explain=1&u=145944', badlocation = 1
WHERE sessionhash = '8385044bee7d6de684cfeaf823df6777'
Time Before: 0.18013 seconds
Time After: 0.18040 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
Page generated in 0.17899608612061 seconds with 9 queries, spending 0.0081465244293213 doing MySQL queries and 0.17084956169128 doing PHP things.
