Time Before: 0.01507 seconds
Time After: 0.02025 seconds
Time Taken: 0.00518 seconds
Time Before: 0.02035 seconds
Time After: 0.02079 seconds
Time Before: 0.02101 seconds
Time After: 0.02113 seconds
Time Before: 0.02194 seconds
Time After: 0.02468 seconds
Time Taken: 0.00274 seconds
Time Before: 0.02121 seconds
Time After: 0.02877 seconds
Time Taken: 0.00757 seconds
Time Before: 0.03411 seconds
Time After: 0.03450 seconds
Time Before: 0.03621 seconds
Time After: 0.03740 seconds
Time Taken: 0.00118 seconds
Time Before: 0.03340 seconds
Time After: 0.03759 seconds
Time Taken: 0.00419 seconds
Time Before: 0.06405 seconds
Time After: 0.06418 seconds
Time Before: 0.07465 seconds
Time After: 0.07589 seconds
Time Before: 0.08402 seconds
Time After: 0.08416 seconds
Time Before: 0.08646 seconds
Time After: 0.08788 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=145967' WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.10537 seconds
Time After: 0.10566 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
