Time Before: 0.00196 seconds
Time After: 0.00253 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00261 seconds
Time After: 0.00304 seconds
Time Before: 0.00328 seconds
Time After: 0.00343 seconds
Time Before: 0.00407 seconds
Time After: 0.00668 seconds
Time Taken: 0.00261 seconds
Time Before: 0.00348 seconds
Time After: 0.01001 seconds
Time Taken: 0.00653 seconds
Time Before: 0.01227 seconds
Time After: 0.01249 seconds
Time Before: 0.01581 seconds
Time After: 0.01713 seconds
Time Taken: 0.00132 seconds
Time Before: 0.01152 seconds
Time After: 0.01736 seconds
Time Taken: 0.00584 seconds
Time Before: 0.02389 seconds
Time After: 0.02401 seconds
Time Before: 0.02612 seconds
Time After: 0.02744 seconds
Time Before: 0.03224 seconds
Time After: 0.03242 seconds
Time Before: 0.03454 seconds
Time After: 0.03595 seconds
UPDATE session SET lastactivity = 1789143036, location = '/forums/private.php?do=newpm&explain=1&u=146009', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.05125 seconds
Time After: 0.05165 seconds
