Time Before: 0.00168 seconds
Time After: 0.00226 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00234 seconds
Time After: 0.00296 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00329 seconds
Time After: 0.00340 seconds
Time Before: 0.00408 seconds
Time After: 0.00663 seconds
Time Taken: 0.00255 seconds
Time Before: 0.00345 seconds
Time After: 0.01001 seconds
Time Taken: 0.00656 seconds
Time Before: 0.01214 seconds
Time After: 0.01245 seconds
Time Before: 0.01367 seconds
Time After: 0.01497 seconds
Time Before: 0.01161 seconds
Time After: 0.01514 seconds
Time Taken: 0.00353 seconds
Time Before: 0.02300 seconds
Time After: 0.02313 seconds
Time Before: 0.02551 seconds
Time After: 0.02680 seconds
End call of global.php: 0.02849292755127
Time Before: 0.02991 seconds
Time After: 0.03007 seconds
Time Before: 0.03211 seconds
Time After: 0.03350 seconds
Time Taken: 0.00139 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=146025', badlocation = 1
Time Before: 0.04706 seconds
Time After: 0.04737 seconds
Page generated in 0.046019077301025 seconds with 9 queries, spending 0.0081727504730225 doing MySQL queries and 0.037846326828003 doing PHP things.
