Time Before: 0.01918 seconds
Time After: 0.02517 seconds
Time Taken: 0.00600 seconds
Time Before: 0.02529 seconds
Time After: 0.02570 seconds
Time Before: 0.02600 seconds
Time After: 0.02615 seconds
Time Before: 0.02694 seconds
Time After: 0.02958 seconds
Time Taken: 0.00264 seconds
Time Before: 0.02621 seconds
Time After: 0.03472 seconds
Time Taken: 0.00851 seconds
Time Before: 0.04243 seconds
Time After: 0.04289 seconds
Time Before: 0.04529 seconds
Time After: 0.04659 seconds
Time Before: 0.04181 seconds
Time After: 0.04678 seconds
Time Taken: 0.00497 seconds
Time Before: 0.08108 seconds
Time After: 0.08124 seconds
Time Before: 0.09219 seconds
Time After: 0.09343 seconds
Time Before: 0.10222 seconds
Time After: 0.10237 seconds
Time Before: 0.10532 seconds
Time After: 0.10680 seconds
UPDATE session SET lastactivity = 1785362288, location = '/forums/private.php?do=newpm&explain=1&u=146056' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.12385 seconds
Time After: 0.12418 seconds
