Time Before: 0.00141 seconds
Time After: 0.00204 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00211 seconds
Time After: 0.00253 seconds
Time Before: 0.00273 seconds
Time After: 0.00285 seconds
Time Before: 0.00384 seconds
Time After: 0.00739 seconds
Time Taken: 0.00355 seconds
Time Before: 0.00290 seconds
Time After: 0.01091 seconds
Time Taken: 0.00801 seconds
Time Before: 0.01289 seconds
Time After: 0.01307 seconds
Time Before: 0.01486 seconds
Time After: 0.01704 seconds
Time Taken: 0.00218 seconds
Time Before: 0.01227 seconds
Time After: 0.01729 seconds
Time Taken: 0.00502 seconds
Time Before: 0.02439 seconds
Time After: 0.02453 seconds
Time Before: 0.02666 seconds
Time After: 0.02792 seconds
Time Before: 0.03203 seconds
Time After: 0.03217 seconds
Time Before: 0.03481 seconds
Time After: 0.03625 seconds
UPDATE session SET lastactivity = 1780645521, location = '/forums/private.php?do=newpm&explain=1&u=146111' WHERE sessionhash = 'f0a2de90bc45baf36aaf71071f1bfe42'
Time Before: 0.05181 seconds
Time After: 0.05213 seconds
