Time Before: 0.00180 seconds
Time After: 0.00246 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00255 seconds
Time After: 0.00306 seconds
Time Before: 0.00334 seconds
Time After: 0.00351 seconds
Time Before: 0.00446 seconds
Time After: 0.00725 seconds
Time Taken: 0.00278 seconds
Time Before: 0.00359 seconds
Time After: 0.01203 seconds
Time Taken: 0.00844 seconds
Time Before: 0.01384 seconds
Time After: 0.01424 seconds
Time Before: 0.01763 seconds
Time After: 0.02042 seconds
Time Before: 0.01319 seconds
Time After: 0.02059 seconds
Time Taken: 0.00740 seconds
Time Before: 0.02659 seconds
Time After: 0.02677 seconds
Time Before: 0.02913 seconds
Time After: 0.03035 seconds
End call of global.php: 0.033109903335571
Time Before: 0.03455 seconds
Time After: 0.03474 seconds
Time Before: 0.03709 seconds
Time After: 0.03854 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=146133'
Time Before: 0.05121 seconds
Time After: 0.05151 seconds
Memory Before: 4,288.695 KB
Memory After: 4,288.938 KB
Page generated in 0.050307989120483 seconds with 9 queries, spending 0.0099806785583496 doing MySQL queries and 0.040327310562134 doing PHP things.
