Time Before: 0.00146 seconds
Time After: 0.00186 seconds
Time Before: 0.00193 seconds
Time After: 0.00239 seconds
Time Before: 0.00267 seconds
Time After: 0.00280 seconds
Time Before: 0.00376 seconds
Time After: 0.00627 seconds
Time Taken: 0.00251 seconds
Time Before: 0.00288 seconds
Time After: 0.01063 seconds
Time Taken: 0.00775 seconds
Time Before: 0.01243 seconds
Time After: 0.01283 seconds
Time Before: 0.01589 seconds
Time After: 0.01706 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01176 seconds
Time After: 0.01724 seconds
Time Taken: 0.00548 seconds
Time Before: 0.02235 seconds
Time After: 0.02248 seconds
Time Before: 0.02448 seconds
Time After: 0.02576 seconds
End call of global.php: 0.027389049530029
Time Before: 0.02867 seconds
Time After: 0.02883 seconds
Time Before: 0.03084 seconds
Time After: 0.03316 seconds
Time Taken: 0.00232 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=146164', badlocation = 1
Time Before: 0.04768 seconds
Time After: 0.04813 seconds
Page generated in 0.04655909538269 seconds with 9 queries, spending 0.0090160369873047 doing MySQL queries and 0.037543058395386 doing PHP things.
