Time Before: 0.00160 seconds
Time After: 0.00208 seconds
Time Before: 0.00215 seconds
Time After: 0.00256 seconds
Time Before: 0.00278 seconds
Time After: 0.00291 seconds
Time Before: 0.00366 seconds
Time After: 0.00747 seconds
Time Taken: 0.00381 seconds
Time Before: 0.00296 seconds
Time After: 0.01089 seconds
Time Taken: 0.00794 seconds
Time Before: 0.01271 seconds
Time After: 0.01309 seconds
Time Before: 0.01551 seconds
Time After: 0.01684 seconds
Time Taken: 0.00133 seconds
Time Before: 0.01215 seconds
Time After: 0.01701 seconds
Time Taken: 0.00486 seconds
Time Before: 0.02196 seconds
Time After: 0.02212 seconds
Time Before: 0.02406 seconds
Time After: 0.02536 seconds
End call of global.php: 0.027036905288696
Time Before: 0.02828 seconds
Time After: 0.02844 seconds
Time Before: 0.03041 seconds
Time After: 0.03187 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=146314', badlocation = 1
WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.04440 seconds
Time After: 0.04469 seconds
Page generated in 0.043440103530884 seconds with 9 queries, spending 0.0094189643859863 doing MySQL queries and 0.034021139144897 doing PHP things.
