Time Before: 0.00137 seconds
Time After: 0.00184 seconds
Time Before: 0.00192 seconds
Time After: 0.00254 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00292 seconds
Time After: 0.00323 seconds
Time Before: 0.00400 seconds
Time After: 0.00655 seconds
Time Taken: 0.00255 seconds
Time Before: 0.00328 seconds
Time After: 0.01033 seconds
Time Taken: 0.00705 seconds
Time Before: 0.01202 seconds
Time After: 0.01233 seconds
Time Before: 0.01429 seconds
Time After: 0.01551 seconds
Time Before: 0.01144 seconds
Time After: 0.01576 seconds
Time Taken: 0.00432 seconds
Time Before: 0.02199 seconds
Time After: 0.02252 seconds
Time Taken: 0.00053 seconds
Time Before: 0.02571 seconds
Time After: 0.02693 seconds
End call of global.php: 0.028704881668091
Time Before: 0.02982 seconds
Time After: 0.03002 seconds
Time Before: 0.03310 seconds
Time After: 0.03452 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=146365'
Time Before: 0.05230 seconds
Time After: 0.05504 seconds
Time Taken: 0.00274 seconds
Memory Before: 4,911.586 KB
Memory After: 4,911.828 KB
Page generated in 0.051198959350586 seconds with 9 queries, spending 0.011106729507446 doing MySQL queries and 0.04009222984314 doing PHP things.
