Time Before: 0.00147 seconds
Time After: 0.00199 seconds
Time Before: 0.00206 seconds
Time After: 0.00250 seconds
Time Before: 0.00272 seconds
Time After: 0.00289 seconds
Time Before: 0.00373 seconds
Time After: 0.00608 seconds
Time Taken: 0.00236 seconds
Time Before: 0.00297 seconds
Time After: 0.01030 seconds
Time Taken: 0.00734 seconds
Time Before: 0.01283 seconds
Time After: 0.01327 seconds
Time Before: 0.01666 seconds
Time After: 0.01848 seconds
Time Taken: 0.00182 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01199 seconds
Time After: 0.01873 seconds
Time Taken: 0.00674 seconds
Memory After: 2,261.820 KB
Time Before: 0.02499 seconds
Time After: 0.02529 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
REPLACE INTO datastore
	(title, data, unserialize)
VALUES
	('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"18.09,\";s:9:\"lastcheck\";i:1789128391;}', 1)
Time Before: 0.03374 seconds
Time After: 0.03446 seconds
Time Taken: 0.00072 seconds
Memory Before: 2,816.633 KB
Memory After: 2,816.883 KB
Memory Used: 0.250 KB
Time Before: 0.03720 seconds
Time After: 0.03857 seconds
Time Taken: 0.00137 seconds
Memory Before: 2,903.938 KB
Memory After: 2,904.531 KB
End call of global.php: 0.04121994972229
Time Before: 0.04293 seconds
Time After: 0.04310 seconds
Memory Before: 3,540.688 KB
Memory After: 3,541.117 KB
Time Before: 0.04601 seconds
Time After: 0.04753 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,822.422 KB
Memory After: 3,824.109 KB
SET lastactivity = 1789128391, location = '/forums/private.php?do=newpm&explain=1&u=146383', badlocation = 1
Time Before: 0.06182 seconds
Time After: 0.06217 seconds
Memory Before: 4,296.438 KB
Memory After: 4,296.648 KB
Page generated in 0.060405969619751 seconds with 10 queries, spending 0.0096638202667236 doing MySQL queries and 0.050742149353027 doing PHP things.
