Time Before: 0.01165 seconds
Time After: 0.02113 seconds
Time Taken: 0.00948 seconds
Time Before: 0.02124 seconds
Time After: 0.02184 seconds
Time Taken: 0.00060 seconds
Time Before: 0.02254 seconds
Time After: 0.02272 seconds
Time Before: 0.02363 seconds
Time After: 0.02659 seconds
Time Taken: 0.00295 seconds
Time Before: 0.02280 seconds
Time After: 0.03180 seconds
Time Taken: 0.00900 seconds
Time Before: 0.04173 seconds
Time After: 0.04216 seconds
Time Before: 0.04348 seconds
Time After: 0.04475 seconds
Time Before: 0.04095 seconds
Time After: 0.04495 seconds
Time Taken: 0.00400 seconds
Time Before: 0.07057 seconds
Time After: 0.07074 seconds
Time Before: 0.08647 seconds
Time After: 0.08777 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.08992600440979
Time Before: 0.09671 seconds
Time After: 0.09688 seconds
Time Before: 0.09942 seconds
Time After: 0.10091 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=146419', badlocation = 1
Time Before: 0.12071 seconds
Time After: 0.12108 seconds
Page generated in 0.11964392662048 seconds with 9 queries, spending 0.0089607238769531 doing MySQL queries and 0.11068320274353 doing PHP things.
