Time Before: 0.00152 seconds
Time After: 0.00201 seconds
Time Before: 0.00208 seconds
Time After: 0.00252 seconds
Time Before: 0.00285 seconds
Time After: 0.00301 seconds
Time Before: 0.00387 seconds
Time After: 0.00645 seconds
Time Taken: 0.00258 seconds
Time Before: 0.00309 seconds
Time After: 0.01109 seconds
Time Taken: 0.00799 seconds
Time Before: 0.01301 seconds
Time After: 0.01339 seconds
Time Before: 0.01582 seconds
Time After: 0.01706 seconds
Time Before: 0.01231 seconds
Time After: 0.01729 seconds
Time Taken: 0.00498 seconds
Time Before: 0.02354 seconds
Time After: 0.02371 seconds
Time Before: 0.02564 seconds
Time After: 0.02688 seconds
Time Before: 0.02973 seconds
Time After: 0.02994 seconds
Time Before: 0.03259 seconds
Time After: 0.03406 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=146578' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.04699 seconds
Time After: 0.04726 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
