Time Before: 0.03029 seconds
Time After: 0.03530 seconds
Time Taken: 0.00500 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.03542 seconds
Time After: 0.03603 seconds
Time Taken: 0.00061 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.03629 seconds
Time After: 0.03645 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.03726 seconds
Time After: 0.03986 seconds
Time Taken: 0.00260 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.03653 seconds
Time After: 0.04415 seconds
Time Taken: 0.00762 seconds
Memory Before: 560.883 KB
Memory After: 1,641.883 KB
Memory Used: 1,081.000 KB
Time Before: 0.05398 seconds
Time After: 0.05459 seconds
Memory Before: 2,136.727 KB
Memory After: 2,137.344 KB
Time Before: 0.05593 seconds
Time After: 0.05721 seconds
Memory Before: 2,148.789 KB
Memory After: 2,148.648 KB
Time Before: 0.05327 seconds
Time After: 0.05744 seconds
Time Taken: 0.00417 seconds
Memory Before: 2,128.906 KB
Memory After: 2,261.672 KB
Time Before: 0.10821 seconds
Time After: 0.10840 seconds
Memory Before: 2,815.242 KB
Memory After: 2,815.758 KB
Time Before: 0.13184 seconds
Time After: 0.13309 seconds
Memory Before: 2,903.539 KB
Memory After: 2,904.133 KB
Time Before: 0.14324 seconds
Time After: 0.14344 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.14645 seconds
Time After: 0.14793 seconds
Memory Before: 3,821.875 KB
Memory After: 3,823.563 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=146603' WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.17116 seconds
Time After: 0.17152 seconds
Memory Before: 4,295.492 KB
Memory After: 4,295.734 KB
